Ardumower Sunray
- 1 Videos
- 3 Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit)
- 4 Installation steps
- 5 Bluetooth BLE UART module
- 6 PCB1.3 GPS pin fix
- 7 PCB1.3 odometry divider
- 8 RTK base
- 9 RTK rover
- 10 Rover configuration (messages)
- 11 Download, Arduino Code, Firmware
- 12 Phone App
- 13 Odometry test
- 14 RTK GPS test (invalid, float, fix)
- 15 Discussion / questions / forum thread
- 16 How the waypoints are generated
- Optimized for Arduino Due
