Ardumower PCB
Needed parts
v0.9.3 (old version - not recommended)
If you know nothing about code, choose v0.9.3 stable code and these parts:
- Main functions
- 1 x Arduino Mega 2560
- 2 x L298N motor driver module
- 3 x current sensor module ACS712-5
- Perimeter sender (optional)
- 1 x Arduino Nano
- Coil 220µH, Elko 2,2µF/160V, Resistors (1 Ohm, 1K, 4,7K), Diode 1N4448
- 1 x L298N motor driver module
- 1 x Arduino Nano
- 2 x Arduino Sound Sensor Module (must use LM386)
- Capacitors (2 x 4,7nF, 2 x 100nF), Resistors (2 x 200k), 2 x Receiver coils 85mH
- Additional modules
SVN version (new version - recommended)
If you want to be ready for the future, choose SVN developer version and the parts listed there.
Schematics
PCB assembly
Single sided PCB "eurocard" dimensions 160x100mm So you can build it yourself !!! All used modules are available in the ardumower shop Uses the arduino mega R3 All connections are available on connectors as +5V and GND
You have two options:
- Download v0.9.3 code (old, not recommended) OR
- Download Download SVN developer code (recommended)
Arduino Version: It is verry Importent that you use the Arduino IDE version 1.5.6-r2 or above AND select the right Board (Mega 2560 or Due).
First-time calibration
Wheel motors
ADC calibration
Diagnostic
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
- config.h (old v9.0.3)
- mower.cpp (SVN version)
pfodApp
