Chassis (English)
- Wheels: 250mm diameter
- Free wheel: 125mm diameter
- Battery: Lithium-Ion 29.4V
- Max. incline: approx. 30%
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
Required Tools
- Screw driver
- Different Torx screw driver
- Knife
Optional Tools
- Round and flat file
- Electric padsaw
Optional Material
- M4 washer and spring washer
- 1 M8 carriage bolt
- Rain sensor case 3D print from model
- Case for NTRIP receiver module for GSPS variant of the Ardumower
Case assembly
Gear motors
Tires
Mower motor
Mowing disc
Free wheel
