Raindancer Firmware (English)
This documentation is for firmware version 2.x.x.
- 1 Download
- 2 Overview
- 4 Optional can be used
- 5 config.h
- 6 QUICK START TO MOW
- 6.1 Errorhandling
- 6.7 Mowmotor commissioning
- 6.8 Perimeter Commissioning
- 6.9 Configure Bluetooth
- 6.10 Configure Arduino Centrale
- 6.11 First test drive
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.4 Undervoltage Shutdown
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.9 Set mower motor current
- 7.11 Archimedean Spiral
- 7.12 Perimeter Tracking
- 7.13 Fast return
- 7.14 Mowing zones between adjacent surfaces
- 7.15 Laying the Perimeter Cable at Corners
- 7.16 Temperature Sensor
- 7.17 Rain Sensor
- 7.18 Shutdown Service
- 7.19 GPS Service
- 8 Perimeter Sender
- 9 Charging Station
- 10 Troubleshooting
Overview
Example: clc.enc
Which modes will start when:
- PCB1.3 with Arduino DUE
- BT module
- 24V power supply
- RTC with EEPROM
Console Speed:
has to be changed to:
Errorhandling
error //show errormessage
show.hist //show history
A
Enter the command:
Enter the command
clc.mt, 1,150
to make the left wheel turn.
Enter then
clc.mt, 2,150
Enter:
then
clc.v, s stop engine
then
Drive a certain way in cm
pc.cm,60,60,30,30 drives 60cm forward with the speed of 30%
z //mow motor start
t //mow motor stop
per.resultl for left coil
and
per.resultr for right coil.
End the output with h.
Configure Bluetooth
Lets start:
Select CR
Select NL
First test drive
#define CONF_ESCAPEDIR_DEPENDING_ON_BUMPER false // if set to true, the robot rotates in the opposite direction of the activated bumper. If false, the escape direction is random. // only set to true if you use a bumper for left and a bumper for right.
Annotation:
Use without charging station
Put in the charging station
Enter the command:
Enable relay:
Disable relay:
With the command
Archimedean Spiral
if(CONF_ACTVATE_AUTO_SPIRAL) { (a) if(bb.mowMotorSensor.motorUnderHeavyLoad) { if(millis()-bb.lastTimeSpiralStarted > 60000ul) { bb.flagCruiseSpiral = true; } } (b) if( (millis()-bb.lastTimeSpiralStarted > 180000ul) && bb.mowMotorSensor.checkIfUnderLoad() ) { // Alle 3 Minuten Spirale starten wenn motor belastet bb.flagCruiseSpiral = true; } }
if ((millis() - lastTransitionTime) > 1000) { // If more than 1sec inside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + 10)); bb.motor.R->setSpeed(-25); }
if ((millis() - lastTransitionTime) > 1800) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECW; bb.motor.L->setSpeed(25); bb.motor.R->setSpeed(-25);
integral = integral + (Ki*error); // the value error is a constant and has the value -1 if the coil is outside the perimeter. double Output = integral;
bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); // note: output is negative bb.motor.R->setSpeed((bb.cruiseSpeed));
if ((millis() - lastTransitionTime) > 1000) { // If more than 2sec Outside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +5)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); } if ((millis() - lastTransitionTime) > 2000) { // If more than 3.5sec Outside rotate full bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); }
if (bb.perimeterSensoren.isLeftOutside() == true) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); waitForRightInside = true; }
The command
stops the test.
With the command
set.lfki, 1.1
Fast return
virtual NodeStatus onUpdate(Blackboard& bb) { ...
//============================================ // Calculate driven angle every 500ms. //============================================ if (millis() - lastRunAngleCalculation >= 500) { lastRunAngleCalculation = millis(); ... angle = (cmL - cmR) * 57.2957795f / CONF_DISTANCE_BETWEEN_WHEELS_CM; if (flagShowFindTriangleStates) { errorHandler.setInfoNoLog(F("Winkel: %f cmL %f cmR %f\r\n"), angle, cmL, cmR); } }
Query the States
// Check for left curve / right curve / second left curve switch (state) {
case 0: // search for left curve if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s0 set state = 1 Left turn found angle: %f ms: %lu\r\n"), angle, millis()); } bb.motor.startDistanceMeasurementTriangle(); ... state = 1; // Activate triangle searching } break;
case 1: // search for right turn distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 55) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 0 distance %f > 55 ms: %lu\r\n"), distance, millis()); } } else if (angle > 50) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 2 angle %f distance %f < 50\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 2; } break;
case 2: // search for second left curve distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 50) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 0 distance %f > 50 ms: %lu\r\n"), distance, millis()); } } else if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 3 angle %f distance %f < -25\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 3; } break;
case 3: if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s3 set state=0 Cross Lawn Activated\r\n")); } state = 0; return BH_SUCCESS; break;
... } return BH_RUNNING; }
See image:
area,x // where x is the path to be traveled in m.
Temperature Sensor
#define DHTTYPE DHT22
temp.show
Rain Sensor
rain.show
Shutdown Service
With the command: poweroff the shutdown can be activated via the user interface or from the PI.
GPS Service
a) The received GPS data will be forwarded to the Raindancer Controlcenter. b) The received GPS data are evaluated in the Raindancer firmware. You can then define an area on the lawn. If the mower is in this area, it is assumed that the mower is inside the perimeter wire. So it is possible to bridge a weak perimeter signal on larger areas.
set.cco, 1
set.cco,0
Enable internal calculation
With
gps.show
const float CONF_LAT_POLYGON_Y[] = { 54.083245f, 54.084068f, 54.084679f, 54.085623f, 54.084018f }; // Latitude polygon points const float CONF_LON_POLYGON_X[] = { 10.447986f, 10.447055f, 10.446015f, 10.447120f, 10.44930f }; // Longitudinal polygon points const int CONF_NUMBER_OF_POLYGON_POINTS = 5; // The number of the ploygon points
Safety Note: If the perimeter signal fails and the GPS range exceeds the perimeter, the mower will leave the perimeter area
- 1. 12V available
- 2. 5V available
- 3. Green when the interrupt which produces the signal is running (red LED not available because of wrong pin at Nano). Off when charging.
- 4. Green when a current flows through the perimeter, red when no current is flowing (perimeter interrupted) or very little current because of high protective resistor. Off when charging.
- 5. Yellow the robot is charging. Perimeter signal is switched off. LED 2 and 4 off.
Charging Station
If no charging station is used, CONF_DISABLE_CHARGINGSTATION = true should be set. Then the Mower drives at low battery voltage to the perimeter and stops.
Head charging station
With the command
gohome
tpt
area,0
Through Charging Station
With the command
gohome
tpt
To leave the charging station enter area,10 The Mower then travels 10m along the perimeter wire and then starts mowing. 10m can be exchanged against any distance.
Mower stops
