Perimeter wire
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
- Perimeter stop test
- Perimeter tracking test
While crossing the perimeter loop, something interesting happens: the signal changes its polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire as well as the current state (robot is inside/outside) will be detected. As with perimeter v1, we will again use a motor driver to generate the signal and an operation amplifier to amplify the received signal. The perimeter sender outputs a code (pseudo-noise), and the receiver will detect that code using a software-based digital matched filter. Depending on wheter the match result peak is positive or negative, the robot is inside or outside of the perimeter wire.
Principle:
- Amplify perimeter coil signal using OPAMP
- ADC sampling using Arduino
- Signal filterung and detection using a digital filter (Matched filter algorithmn).
- Evaluation of filter output
Simulation
You can see how it works:
The motor driver is driven by 3.2 Khz (two pulse widths 4.8 Khz and 2.4 Khz). The circuit draws max. 20W (12V, 1.7A). We use a motor driver with integrated current limiting and thermal switch-off (e.g. MC33926). The perimeter wire length should be in the range 20m - 450m.
sender circuit:
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Software
- define USE_POT for adjust if use an Poti to adjust the Power Out of the Perimter
and
- define USE_CHG_CURRENT if you set it to 1 the Perimter shuts off while the Mower is Charging, if the Charger is not
connected set to 0
Example of sender implementation on a dot matrix board: [1]
[2] [3]
Receiver
receiver circuit:
LM386 IN o------- capacitor 4,7nF ----------- coil 100 mH
Flux directions
ADC calibration
Note: Run the ADC calibration once ("pfodApp->ADC Calibration"), so that the received signal is symmetric around zero. The Perimeter Transmiter must be off while Calibration.
Diagnostics
Sender status LED (Arduino LED):
sig: coil signal mag: filter result: inside (negative) or outside (positive), strengh: distance to perimeter wire - this is used for perimeter tracking smag: filter result, low-pass filtered, without sign (smooth mag) - this is used for 'sender-off' detection in: binary result, low-pass filtered: inside (1) oder outside (0) - this is used for perimeter boundary detection cnt: number of "inside-outside" transitions (counter) on: perimeter sender active (1) or inactive (0)
