Bluetooth
Version vom 20. Dezember 2014, 10:41 Uhr von Alexanderg (Diskussion | Beiträge)
- via your phone (Anrdoid)
- via your PC (USB Bluetooth dongle)
On the phone, you'll need the App 'pfodApp'. Alternatively, you can use the App 'ArduRemote'.
The phone menu includes:
- Settings (Timer etc.)
Bluetooth module
On the robot, you'll need a Bluetooth module. Depending on the desired range, you can use different Bluetooth classes:
- Bluetooth class 2 (up to approx. 50m range), e.g. HC03/04/05/06
- Bluetooth class 1 (up to approx. 100m range), e.g. BTM220, requires additional circuit
Bluetooth HC-05
Steps
- Baud rate: Blueooth module and Arduino Mega must use the same baud rate (19200) - The baud rate of the BT module can be changed via Ardumower serial console. Connect Ardumower Mega board to your PC (USB), enter the serial console in the Arduino IDE (CTRL+M), and choose baud rate 19200, then choose 'd' to enter the Ardumower menu to configure the module to the correct baud rate.
pfodApp communication protocol
The communication protocol between robot and pfodApp is defined in the 'pfodSpecification' and can be found here: http://www.forward.com.au/pfod/.
