Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
Reboot All Using Start icon and Log Out.
First connection over Wifi
PC SIDE or Tablet / Phone
You need to use real VNC Viewer to connect to the PI over your network.
Instal the software
