Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
