Level 2 Raspberry Pi
What you need
Advance user
If you already know how raspberry PI work with desktop ,You can follow the fast setup process locate
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
Pi Software part
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install idle3
sudo pip3 install paho-mqtt
sudo apt-get install kst
cd Downloads/arduino-1.8.13
sudo ./install.sh
