AzuritBer Pi Explain (English)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
m --> Start Blade
q --> Stop Blade
Up --> Forward
Down --> Reverse
Right --> Turn right
Left --> Turn left
Space --> Stop all
