Version vom 21. November 2020, 11:26 Uhr von Bernard (Diskussion | Beiträge) (→‎Piardu Configuration)
Level 2 Raspberry Pi
Setup
What you need
Fast setup for Advanced user
Here the full setup process:
sudo apt-get install idle3
sudo pip3 install paho-mqtt
sudo apt-get install kst
sudo apt-get install dos2unix
cd ~/Documents
sudo chmod -R 755 PiArdumower
cd PiArdumower
mv mower.sh /home/pi/Desktop
cd ~/Documents/PiArdumower
dos2unix streamVideo320.py
dos2unix streamVideo640.py
dos2unix DueFlash.py
dos2unix PowerOff.py
dos2unix Restart.py
dos2unix testnet1.py
cd ~/Desktop
dos2unix mower.sh
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
sudo apt-get update
sudo apt-get upgrade
Python3 Idle
Pygame
Paho Mqtt
KST Plot
DosToUnix
Arduino IDE
cd Downloads/arduino-1.8.13
sudo ./install.sh
PiArdu Software
Using VNC Viewer :
cd Documents
cd PiArdumower
cd Documents/PiArdumower
dos2unix Restart.py
cd ~/Desktop
dos2unix mower.sh
DUE Connection
Warning.pngFIRST ADJUST THE DC/DC TO 5V OUTPUT or you are going to destroy the raspberry
On setting main tab use Update the DUE Firmware button and click on Start Flash
Again click Back icon and Setting icon and click on Reboot All
The Raspberry and DUE reboot
if you use the PCB1.3 maybe you need to activate raspberryPi use to YES into arduremote / Setting / Raspberry.
Automatic start on Power up:
If you can't see the bottom red line with date time : check if you have activate raspberryPi to YES using Arduremote / Setting /raspberry
Optional Screen
Be carreful when you order : HDMI adaptor is not the same for PI4 (Right Picture) and PI3B+ (center and left Picture)
To setup the tactile and screen :
Go to terminal :copy and paste these command
cd LCD-show/
sudo ./LCD5-show
Optional Camera
Check to Enable the Camera
Move windows or Hit Tabulation 10 times because you can't see Validate Button and press Enter (Reboot)
Inside folder : home/pi/Documents/Piardumower you can edit the config.py file to manage different option :
PCB part:
GPS part:
Warning : GPS is not use by software,it's only a tracker version, All data are recorded and saved inside Piardumower/Gpsdata
Arduino Nano part.
NanoConnectedOnPi
Battery part:
AutoRecordBatCharging
Debug part:
UseDebugConsole
Sender part:
Camera part:
myCamAngle
streamVideoOnPower
Piardu Start video
Result after everything correctly set : https://youtu.be/Qhv8r2bD_Bk
Piardu Description
It's here : [[1]]
