AzuritBer Pi Explain (English)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
Setting Page
Main setting
Simple Setting
Perimeter Setting
Here you can find new button use to start and stop other area sender
