AzuritBer Pi Explain (English)
Version vom 21. November 2020, 12:36 Uhr von Bernard (Diskussion | Beiträge) (→‎DUE Firmware Update)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
m --> Start Blade
q --> Stop Blade
Up --> Forward
Down --> Reverse
Right --> Turn right
Left --> Turn left
Space --> Stop all
Setting Page
Main setting
All page are store on tab item :
Simple Setting
DUE Firmware Update
You can upload a new version of AZURITBER in DUE over WIFI.
Warning.png JP8 need to be in always ON mode during the Flash process, When DUE flash it can power OFF PCB1.3 and flash fail,
Click on Start Flash and wait less than 2 minutes  : process if faster than with PC and programming port. After a while Due Flasher page disappear and check in console than restart is OK with new firmware
Do not forget to set JP8 in Autom Mode
Perimeter Setting
Here you can find new button use to start and stop other area sender
ByLane Setting
