AzuritBer Pi Explain (English)
Version vom 22. November 2020, 12:29 Uhr von Bernard (Diskussion | Beiträge) (→‎RFID Page)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
m --> Start Blade
q --> Stop Blade
Up --> Forward
Down --> Reverse
Right --> Turn right
Left --> Turn left
Space --> Stop all
Setting Page
Main setting
All page are store on tab item :
Simple Setting
DUE Firmware Update
File ardumower.ino.bin is automatically delete from folder to avoid error on next flash : File can't contain "(" or special char
ByLane Setting
Console Page
Test Page
Plot Page
For more info see KST internet page : https://kst-plot.kde.org/
Timer Page
Video Page
To see live stream Use a browser with IP of you PI and :8000
GPS Page
File are locate in gpsdata in PI sd card :
RFID Page
Description is here :
