AzuritBer Pi Firmware RFID(English)
It use SPI interface to communicate with ESP32 and ESP32 replace the bluetooth module HC05 to communicate with PCB1.3, so you can build a small PCB to connect all wire, or order some of them from JLCPCB for example (The same board is also use to build the WIFI sender.)
If everything is OK you can see last tag code in console or into Arduremote each time you move a tag near the reader
