AzuritBer Pi Firmware RFID(English)
Hardware connecting
Using arduino IDE , You can download firmware inside ESP32 to have everything working : https://github.com/Boilevin/AzuritBer/tree/master/ESP32_RFID
Setting
2 Value need to match to have a mower react (TODO) : TAG Nr AND Mower STATUS
Mower can DO : 'RTS' or 'FAST_START' or 'SPEED' or 'NEW_AREA'
RTS is return to station : Mower roll
