AzuritBer Pi Firmware RFID(English)
Hardware connecting
Setting
2 Value need to match to have a mower react (TODO) : TAG Nr AND Mower STATUS
Mower can DO : 'RTS' or 'FAST_START' or 'SPEED' or 'NEW_AREA'
Here example of RTS it is return to station and can be use to escape from island or simply fast return to station :
When tag 1AD8DB95 is find AND mower Status is TRACK_TO_START , Mower stop tracking roll 28 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Here example of FAST_START it can be use to go very fast from one location on the wire to other one when tracking to find a new area :
When tag 72B8DB95 is find AND mower Status is BACK_TO_STATION , Mower stop tracking roll 50 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Here example of new speed it can be use to Dock at low speed or simply change tracking speed when you want :
Here example of area change it can be use to Go to a new mowing area (with other sender) :
When tag 8ECDDB95 is find AND mower Status is BACK_TO_STATION , Mower stop tracking roll -82 Degree ,stop to read perimeter signal ,run at new PWM speed of 200 for the next 10 meters , roll again -90 and run for 0.5 meters ,Start the Sender over WIFI,Check if signal is OK and start to find again perimeter wire to mow on the new area.
