DIY Brushless Driver Board
Version vom 10. Februar 2021, 00:05 Uhr von BerndS (Diskussion | Beiträge) (→‎Test the motor and adapt the parameter)
Description
Before you start the assembling of the Driver Board, we will build the programmer. To build your own programmer for the controller DRV8308, you need an Arduino Nano and a 5 pin JST-XH plug with cramped wires. Solder the wires as shown in the picture and ready is the programmer hardware. Download the Nano program, you can finde here, and load it on the Arduino Nano.
Connector Pinout
Building the PCB and connect the cable
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCB. Lets go to step 2
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
All power is off for Driver Board and Arduimo Nano Programmer. You have connected the power, the motor coils, and the HAL sensors. Bridge the EN signal (pin2) and GND (pin 7) on the 8 pin flat cable connector and plug in the Nano SPI plug into the SPI Board connector. Brushless Driver connector JST-XH 5pol Ok, now cablinbg is done. Please double check the right 24V polarity of the board power.
Ok, the next step will start your motor! Be prepared to power off the 24V power if the motor jammed. Now you can plug in the USB connector into the Arduino Nano to power on your programmer. After 1-2 seconds the Motor will start turning.
