DIY Brushless Driver Board
Version vom 19. April 2021, 12:37 Uhr von BerndS (Diskussion | Beiträge) (→‎Brushless Drive Test Software)
Description
  1. define Reg00
  1. define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[2], at page 37-40.
Attention, before you burn the double check that you have changed the speed control from SPI (default in the program) to PWM!
Connector Pinout
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCB. Lets go to step 2
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
