DIY Brushless Driver Board
Version vom 26. April 2021, 23:45 Uhr von BerndS (Diskussion | Beiträge) (→‎Brushless Drive Test Software)
Description
  1. define Reg00
  1. define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[2], at page 37-40.
Connector Pinout
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCB. Lets go to step 2
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
Bug fix
The odometry divider caused a problem with the BL odometry signal. The ArduMower will drive not synchronized, one wheel is slower. You can fix it with a 220nF an each ot the odometry inputs.
220nF at each odometry input
