DIY Brushless Driver Board
Version vom 10. Mai 2021, 08:32 Uhr von BerndS (Diskussion | Beiträge) (→‎Build BL Driver Board and connect the cable)
Description
Brushless Drive Test Software
  1. define Reg00
  1. define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[2], at page 37-40.
Connector Pinout
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCB. Lets go to step 2. But one tip. Plug all the pin connectors for the adapter board first into the sockets from PCB1.4. Then put the Adapter board PCB over the pins and solder them carefully. This is the best way to ensure exact fitting and plug in of the adapter board.
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
Bug fix
The odometry divider on PCB 1.x caused a problem with the BL odometry signal. The ArduMower will drive not synchronized, one wheel is slower. You can fix it with a 220nF an each ot the odometry inputs.
220nF at each odometry input
