DIY Brushless Driver Board
Version vom 20. Juni 2021, 12:11 Uhr von BerndS (Diskussion | Beiträge) (→‎DIY ArduMower Brushless Driver Kit)
PCB1.x with Brushless Driver(Pic. by Uwe)
 Brushless Drive [2]
 Brushless Adapter [3]
Description
Brushless Drive Test Software
  1. define Reg00
  1. define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[4], at page 37-40.
Connector Pinout
Step 1 Soldering :
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
3D-printed PCB holder
Bug fix
See the combination changes of Brushless Adapter Version in combination with BL Driver Version. Link:
The odometry divider on PCB 1.x caused a problem with the BL odometry signal. The ArduMower will drive not synchronized, one wheel is slower. You can fix it with a 220nF an each ot the odometry inputs.
220nF at each odometry input
Take care that the yellow fuses on the PCB1.4 do not get in contact with the BL adaperter board. This can blow up the motor driver board!
Fuse on PCB1.4, wire going up, over the fuse before they turn down
