DIY Brushless Driver Board
Version vom 4. August 2021, 10:10 Uhr von BerndS (Diskussion | Beiträge) (→‎Build BL Driver Board and connect the cable)
PCB1.x with Brushless Driver(Pic. by Uwe)
 Brushless Drive [2]
 Brushless Adapter [3]
Description
Brushless Drive Test Software
  1. define Reg00
  1. define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[4], at page 37-40.
Connector Pinout
HAL Sensor:
clamp + : 5V Power out for HAL sensoric (ACT Motor HAL cable : red )
clamp - : GND for for HAL sensoric (ACT Motor HAL cable : black )
clamp U : HAL sensor U (ACT Motor HAL thin cable : yellow )
clamp V : HAL sensor V (ACT Motor HAL thin cable : green )
clamp W : HAL sensor W (ACT Motor HAL thin cable : blue )
Motor Coils:
clamp U : coil U (ACT Motor HAL thick cable : yellow )
clamp V : coil V (ACT Motor HAL thick cable : green )
clamp W : coil W (ACT Motor HAL thick cable : blue )
Step 1 Soldering :
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
3D-printed PCB holder
Bug fix
220nF at each odometry input
Fuse on PCB1.4, wire going up, over the fuse before they turn down
