3D-printed extensions and replacements (English)
Version vom 28. September 2021, 18:31 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter sensor case)
This page collects some Ardumower-specific extensions and replacements that can be created by using a 3D-printer.
PCB holder
IMU holder
https://forum.ardumower.de/threads/halterung-f%C3%BCr-mpu-6050-imu-an-der-hauptplatine.24459/#post-49752
Mowing motor holder and height adjustment
Ardumower front panel with IMU holder
https://forum.ardumower.de/threads/neue-frontpartie-f%C3%BCr-standard-chassis.24165/
Mowing motor protection ring
The protection ring is mounted at the chassis bottom (v1) or at the motor bottom (v2) to get rid of gras on the motor shaft, reduce dust etc.
Download v1
Download v2
Universal tire adapter
For even higher traction, one can use pushcart tires from the shop. Using a 3d printed adapter one can mount them onto the Ardumower clamping element. This is an universal tire adapter version, everything can be adjusted (requires OpenSCAD).
1. Download universal tire adapter for OpenSCAD
2. pushcart tires adapter (STL)
Profile 4040, 120 mm
This is a standard 4040 profile with a length of 120 mm. It can be used to replace the standard metal profile which might possibly improve EMC-characteristics for the inductive perimeter sensor.
Profile 4040, 30 mm-version for illustration
Download from Thingiverse
Sheep Sheep spikes for wheels
Download from Github
