Version vom 30. Dezember 2021, 00:12 Uhr von BenPan (Diskussion | Beiträge) (→Code: updated links to github)
Ardumower's bumper sensor (called 'BumperDuino') is based on a pressure sensor and helps us to detect obstacles.
The PCB module and sensor can be purchased as complete kit via the shop
Building instructions
Building instructions as well as instructions for programming the Arduino can be found in the BumperDuino manual.
Schematics
Code
You can download the Arduino Code here. Important: Choose 'Arduino Uno' as bootloader.
To upload the code, set jumper to 'VUSB' and connect an USB-TTL adapter to J4 (USB-LIGHT) as follows:
J4 (USB-LIGHT) 1 -- USB-TTL GND 2 -- not used 3 -- USB-TTL +5V 4 -- USB-TTL TX 5 -- USB-TTL RX 6 -- USB-TTL DTR (reset)
All steps are described in more detail here: FT232RL USB-adapter manual.
Connecting to Ardumower
Set jumper to 'VIN', and connect VIN and BUMPER-OC to Ardumower as follows: BumperDuino VIN + -- PCB1.3 +9V BumperDuino VIN - -- PCB1.3 P11 GND (2) BumperDuino OC DC1 -- PCB1.3 P11 pinBumperRight (3) BumperDuino OC DC2 -- PCB1.3 P11 pinBumperLeft (4)
BumperDuino and tilt protection
The BumperDuino is permanently improved. Here you can find a version including tilt protection:
BumperDuino using tilt protection
