AzuritBer RFID option (English)
Version vom 5. Februar 2022, 11:04 Uhr von Bernard (Diskussion | Beiträge) (→‎Change tracking speed)
Description
It's very useful on big mowing area or complex one with a lot of island.
Hardware connecting
FIRMWARE ESP32
see here :
https://wiki.ardumower.de/index.php?title=AzuritBer_ESP32_option_(English)
you need to activate the RFID in config.h before uploading code in the ESP32
#define rfid_board_IsPluged true //Set to true or false according your hardware
If everything is OK you can see Last Rfid tag code into Arduremote / setting / RFID each time you move a tag near the reader and if it's a new tag : a record is add with a WAIT status and nothing to do.
Setting
Go to arduremote / Setting / Rfid menu to edit or delete tag
When mower track the wire it use a status ,for example "TRACKTOSTART" or "WIREMOWING" etc...
According this status and the Tag ID that mower find on the wire you need to set a TODO value to indicate what you want:
So 2 Value need to match to have a mower react (TODO) : TAG Nr AND Mower STATUS
Edit a record
From RFID List ,click on on tag Nr to see the detail menu:
Now change Status, ToDo and all slider according your need:
For permanent backup hit SAVE LIST to save your change in the mower eeprom.
As 1 tag can be use for different ToDO you can use the DUPLICATE OPTION to have multiple record.
Hit DELETE THIS TAG to remove the tag from database .
Move a tag near the reader to add a new one.
What is possible
Mower can DO : 'RTS' or 'FAST_START' or 'SPEED' or 'AREA1' or 'AREA2' or 'AREA3'
Fast Return to station
Speed and Ang 1 are used
When tag 72B8DB is find AND mower Status is BACK_TO_STATION ,if you put RTS in the TODO column : Mower stop tracking roll 28 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Fast Start
When tag 703a7f81 is find AND mower Status is TRACK_TO_START ,if you put FAST_START in the TODO column : Mower stop tracking roll 60 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Can be use to Dock at low speed or simply change tracking speed when you want : ON big straight line mower can track at PWM=255 or on hard angle you can reduce the tracking speed
Speed and Dist1 are used.
When tag 703a7f81 is find AND mower Status is WIRE_MOWING , Mower continue tracking but run at new PWM speed of 80 for next 100 cm.
Go to new mowing Area
Can be use to Go to a new mowing area (with other sender)  :
It is used to back to charging station from other mowing area  :
Result in Video
Here a fast start to go in area2 :
At 1:34 The AREA2 tag is find : mower stop to read area1 signal and start to go to area2 (NO wire under asphalt)
AT 2:56 mowing in AREA2 start
At 1:52 Change area tag is find : Mower stop AREA2 sender and move to AREA1 without reading perimeter signal.
