Arduino first steps
Version vom 24. November 2014, 12:53 Uhr von Alexanderg (Diskussion | Beiträge)
All you need to 'upload' the example code to your Arduino is:
- One USB cable
2. Download
Click here to download the Arduino development software (v1.5.8) to your computer (Windows users should download the 'Installer' version on that page):
3. Install
4. Run
5. Choose blink example
6. Choose correct board type
8. Upload the blink example
Click on the 'Upload' symbol to upload the blink example to your Arduino. After the upload completed, your Arduino will start to blink!
Congratulations!
Now let's look a little bit closer at the blink code to understand it:
The Arduino has several pins, each of them has a number, and each of them can be configured as either INPUT or OUTPUT depending on wheter you want to measure (read) or control (write) to it:
INPUT means that you can read (or measure) that pin. The measurement can be either ON (there is voltage on that pin) or OFF (there is no voltage on that pin). OUTPUT means that you can write (or control) the voltage of that pin.
In the blink example above, we are using the LED pin (pin 13) that is already connected to an LED. Because we want to control that pin, we are configuring it as OUTPUT.
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
Let's see how we can wait one second between the ON and OFF toggling. This command will wait (halt) the program for one second:
delay(1000);
