Ardumower Chassis 'mountain mod'
Version vom 25. März 2022, 18:24 Uhr von Alexanderg (Diskussion | Beiträge) (→‎New rubber tires (optional))
  2. optional: modifying the tire profile (give it more grip)
    1. Modify tire profile OR
Needed parts
  • cup
  • acrylic glas sheet (1mm)
  • rubber band (U-form)
  1. on Ardumower PCB, swap right motor cables with left motor cables (so left motor is right motor and vice versa)
  2. on Ardumower PCB, swap polarity of each motor by swapping motor (+/-) pins (so turning forward is turning backward) NOTE: for brushless motors, swap two arbitrary phases (U,V,W) to swap motor polarity
  3. on Ardumower PCB, swap odometry cables (so left odometry is right odometry and vice versa)
  4. mount battery charging pin at chassis handle side
  5. disable ultrasonic sensor
  6. move perimeter coil from old front to old back side (if using perimeter sensor)
  7. use BumperDuino as bumper sensor
For even higher traction, one can use pushcart tires from the shop. Using a 3d printed adapter one can mount them onto the Ardumower clamping element. NOTE: The trick here is to first insert the long screws into both printed adapters, and then rotate the adapters until they fit onto the tires.
pushcart tires adapter
Pictures
  1. Ardumower rear/front driven climbing difference
  2. Ardumower rear-driven, BumperDuino demo
  3. pushcart tires
  4. Demo
  5. Optimized tires
  6. Bicycle tube tires for 'off-road'
Other ideas
Forum
