Motor driver
Version vom 21. Januar 2015, 19:02 Uhr von Alexanderg (Diskussion | Beiträge) (→‎MC33926 (recommended))
Ardumower's design uses two different types of motors (all motors can be purchased via the shop Shopping.png):
  • Two motors (with integrated gearing) for driving (wheel motors)
Voltages
  • The motor driver must be suitable for higher current (more expensive)
  • The PCB traces need to be more thick (more expensive)
  • The rechargable battery need to support higher current (more expensive)
Wheel motors
  • steer the robot left/right
  • A rotation speed up to 33 rpm allows to move the robot at sufficient speed
  • A high torque (3Nm) guarantees that the robot can climb small hills as well
  • Integrated encoders, so it can measure the rotation speed. This allows Ardumower to correct the driving angle (see Odometry for more information)
  • 24V
Motor driver
 Arduino Digital Pin  —>  MOTOR-Direction Pin (DIR)
 Arduino PWM Pin      —>  MOTOR-Speed Pin (PWM)
 Arduino Analog Pin   <—  MOTOR-Current Sensor Pin
Popular modules
For the 0.9.3 Version
M1_FB     --- Motor1 current sensor output (Arduino)
M1_IN1    --- Motor1 PWM (Arduino)
M1_IN2    --- Motor1 Dir (Arduino)
EN        --- connect with jumper to VDD
M2_FB     --- Motor2 current sensor output (Arduino)
M2_IN1    --- Motor2 PWM (Arduino)
M2_IN2    --- Motor2 Dir (Arduino)
VDD       --- Arduino 5V
For the SVN Version
M1_FB     --- pinMotorLeftSense A1
M1_SF     --- pinMotorLeftFault 25
M1_IN1    --- pinMotorLeftPWM 5
M1_IN2    --- pinMotorLeftDir 31
M2_FB     --- pinMotorRightSense A0
M2_SF     --- pinMotorRightFault 27
M2_IN1    --- pinMotorRightPWM  3
M2_IN2    --- pinMotorRightDir 33
VDD       --- Arduino 5V
L298N
Connect in parallel:
IN1 with IN4
IN2 with IN3
OUT1 with OUT4
OUT2 with OUT3
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.).
L9958 GND---GND
L9958 VCC---Arduino 5V
L9958 EN---Arduino 5V
L9958 DI---GND
L9958 DIR---Arduino MOTOR_DIR
L9958 PWM---Arduino MOTOR_PWM
L9958 MOTOR(+)---motor(+)
L9958 MOTOR(-)---motor(-)
L9958 POWER(+)---battery(+)
L9958 POWER(-)---battery(-)
Mower motor and driver
  • Enough torque (140 mNm)
  • 24V
Choosing a driver
  • price
Short-circuit current
Warning
  • always remove blades
Example measurement:
  • Rotenbach SPM08-320
    • Wheel motor: 8A
    • Mowing motor:
  • Ambrogio L50
    • Wheel motor: 4,5A
    • Mowing motor: 22A
  • Tianchen TC-G158
    • Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
