Charging
Basic principle
Charger
For the charger, we are using a Lithium Ion e-bike charger (29.4V). The charger is placed in a protected area (house etc.) and connected to the robot charging station. The charger should accomplish the following things (in this case Lithium-Ion, lead battery is similar, but less critical):
Battery
For the battery, we are using a 'Sony Konion 7S2P' Lithium Iion battery pack, 29.4V, 4500 mAh 500 recharge cycles, 126 x 36 x 65 mm (LBH).
Robot
In the robot itself, the battery voltage is monitored (see diagram below). So it can be determined when the robot must go to the charging station. The robot and the voltage and the current during charging is controlled. So it can be determined whether the robot has reached the charger and when the battery is fully charged again. Ideally, the charging station also eat the loop transmitter:
charging station circuit:
Charger 24V (+)----- DC-DC converter 5V => Perimeter sender Arduino Nano
robot charging circuit:
---- voltage sensing
Charge plotting
Via pfodApp (Android) you can get a plot of the charging process.
Charging station ideas
