Motor driver
Voltages
Wheel motors
- steer the robot left/right
- A rotation speed up to 33 rpm allows to move the robot at sufficient speed
- A high torque (3Nm) guarantees that the robot can climb small hills as well
- Integrated encoders, so it can measure the rotation speed. This allows Ardumower to correct the driving angle (see Odometry for more information)
- 24V
Motor driver
Popular modules
MC33926 (recommended)
L298N
Connect in parallel:
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.).
Mower motor and driver
- Enough torque (140 mNm)
- 24V
Choosing a driver
- price
Short-circuit current
Warning
- always remove blades
Example measurement:
- Rotenbach SPM08-320
- Wheel motor: 8A
- Mowing motor:
- Ambrogio L50
- Wheel motor: 4,5A
- Mowing motor: 22A
- Tianchen TC-G158
- Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
