Inertialsensor - IMU
Version vom 16. Juli 2015, 18:03 Uhr von Pemiso (Diskussion | Beiträge) (→‎Acceleration sensor)
Beschleunigungssensor
                noise dps/sqrt(Hz)
L3G4200D        0.03
BMG160/BNO055   0.014
MPU9150         0.005
Additionally, gyro/acceleration and compass sensors can be further input to a position estimation.
IMU modules
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
MPU9150
Calibration abstract
Example measurements
Calibration (latest version)
Calibration quality test
Table test
calls=30    yaw=-95.56    pitch=0.02    roll=2.52    com=-95.91    com180=84.09    gyroZ=0.00
calls=30    yaw=-95.48    pitch=-0.11    roll=2.33    com=-95.81    com180=84.19    gyroZ=-0.01
calls=30    yaw=-95.42    pitch=0.03    roll=2.42    com=-95.65    com180=84.35    gyroZ=-0.00
calls=30    yaw=-95.45    pitch=-0.21    roll=2.38    com=-95.35    com180=84.65    gyroZ=-0.00
calls=30    yaw=85.06    pitch=-2.50    roll=0.04    com=84.91    com180=-95.09    gyroZ=-0.03
calls=30    yaw=84.90    pitch=-2.59    roll=0.05    com=84.63    com180=-95.37    gyroZ=-0.02
calls=30    yaw=85.19    pitch=-2.55    roll=0.01    com=84.73    com180=-95.27    gyroZ=-0.01
calls=30    yaw=84.98    pitch=-2.73    roll=0.02    com=84.85    com180=-95.15    gyroZ=-0.01
pfodApp test
Calibration (old v0.9.3)
This one-time calibration ensures that all 3 axes measurements are weighted equally. This calibration can even be performed externally to the robot.
2.1. After calibration, each of the 6 sides of the module has to look up-side and down-side (rotated 180 °). The module has 6 sides, so it must be rotated 6 times, so that each side once is on the table (you can hold the module with your hand without moving it). Press ENTER after each calibration step. The aim of the calibration to determine the acceleration due to gravity (more precisely, the minimum / maximum value) for each axis . The module must not be artificially accelerated. The order of the sides does not matter.
1. Download ArduMag calibration app for Android. 2. If not done yet, pair your Android device with the Bluetooth module: On the Android device main screen, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired". 3. In the ArduMag app, press the Android menu key and then "Bluetooth" to connect with your Bluetooth module (and your robot). The robot should confirm the connection with a beep. The number of measurements should increase.
The order of the axis of rotation and the direction does not matter. For example, rotate each side 180 degree clockwise and then again 180 degree counterclockwise (result is a 360 degree rotation). The measurements may not fit a sphere. Examples:
Finally, press 'Calibrate' to finish the calibration. The robot will confirm the calibration with two beeps. The measurements should fit a sphere now. Examples:
Compass deviation
Calibration test
Testen von Kompass und Neigungswinkeln über die serielle Konsole
Folgende Werte gibt der Arduino aus:
Testen per LED
Testen per Android pfodApp
  1. Tanz des Roboters
  2. Spur halten
  3. Parallele Bahnen fahren
weiterführende Links
