Wheel Motor
Version vom 5. Dezember 2015, 23:01 Uhr von Pierlau38 (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „= Wheel motors caracteristics & driver = <gallery> File: ardumower_motor.jpg | Ardumower gear motor with encoder (8mm diameter, 5900 rpm motor, 0.055 Nm, gea…“)
- steer the robot left/right
- Integrated encoders, so it can measure the rotation speed, the distance and the direction (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
- 24V (load current ~1A)
Wiring
Protection board is advice to be used between controler and motor.
Control principal : PWM frequency
Programming
/!\ work on going !
