Ardumower future PCB
Version vom 22. Januar 2016, 14:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Commuincation protocol)
Architecture
  • existing MCU (Mega) board for the controlling (actuators), sensing (sensors) - basically, current Ardumower PCB
  • new CPU board for high-level control (brain), examples: Rasperry Zero
  • commuincation interface and protocol (based on RS232 interface and session protocol)
  • additional (plug&play) IDE (including compiler & drivers) for the new CPU board
  • Java interface?
Commuincation architecture
  • shared bus (RX/TX) for all sensor/actuator devices
  • open collector (OC) outputs for signal triggers/interrupts
  • TX/RX for communication protocol (session-based)
CPU hardware support/drivers
  • For the driver side, ChibiOS could be a very nice start . It's an RTOS with high integration of hardware drivers , FATFS integration, LWIP etc...
http://www.chibios.org/dokuwiki/doku.php?id=chibios:matrix
http://www.stevebate.net/chibios-rpi/GettingStarted.html
IDE/compiler for CPU
  • emBlocks (integrated compiler for many CPUs including Rasperry PI, STM32, etc.)
  • chibistudio (modified Eclipse)
Running new code on the CPU
  • For debugging purpose, a serial connection (TX/RX) should be available for running new code, debugging
  • For end-users, a small binary (SD card) should be available for download
