Version vom 11. Januar 2017, 16:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎ultrasonic sensor data event)
Robot Mower Communications Standard (RMCS) - *** DRAFT ***
TODO:
  • add sensor trigger events
  • add robot setup commands
Message format
message components:
  • $: start of message symbol
Messages
commands:
  • $RMTRG: Configure a sensor trigger
events:
  • $RMBUM: bumper sensor event
  • $RMODO: odometry event
  • $RMGPS: GPS event
  • $RMDRO: drop sensor event
  • $RMIMU: IMU event
Command: Request or onfigure a message event (frequency, one-time events)
$RMREQ,MSG,f,t<cr><lf>
Command: Set mowing state (start,stop,dock)
$RMMOW,s<cr><lf>
Command: Move robot until sensor trigger
$RMMOV,m,l,r,p,i,d<cr><lf>
  • l: left motor target rpm
  • r: right motor target rpm
  • p: PID_Kp
  • i: PID_Ki
  • d: PID_Kd
Command: Keep ongoing action (mower communications saftety)
$RMKOA<cr><lf>
Event: Robot state (robot state, errors, battery, charger)
  • ts: timestamp ms
  • e: error code
  • b: battery percent
  • bl: battery low (0/1)
  • c: charging percent
Event: Robot mower configuration (protocol version, type of sensors)
  • o: Odometry available (1/0)
  • g: GPS available (1/0)
Event: motor current sensor data
  • ts: timestamp ms
Event: ultrasonic sensor data
  • ts: timestamp ms
  • ul: ultrasonicLeft meter
  • ur: ultrasonicRight meter
  • uc: ultrasonicCenter meter
bumper sensor data event
  • ts: timestamp ms
  • bl: bumperLeft value
  • br: bumperRight value
  • bc: bumperCenter value
  • blt: bumperLeft triggered (0/1)
  • brt: bumperRight triggered (0/1)
  • bct: bumperCenter triggered (0/1)
odometry data event
$RMODO,ts, ol, or
  • ts: timestamp ms
  • ol: left odometry
  • or: right odometry
GPS data event
$RMGPS,ts, ga, go
  • ts: timestamp ms
  • ga: GPSlatitude
  • go: GPSlongitude
perimeter sensor data event
  • ts: timestamp ms
drop sensor data event
$RMDRO,ts,dl,dr,dlt,drt
  • ts: timestamp ms
IMU data event
$RMIMU,ts,ih,ip,ir,tr
  • ts: timestamp ms
  • ip: IMUpitch degree
  • ir: IMUroll degree
  • tr: tilt triggered (0/1)
  • t: timestamp ms
Proprietary
