Motor driver
Version vom 11. September 2014, 19:27 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Wheel motors (H-Bridge))
Arduino Digital Pin —> MOTOR-DIR Pin
Arduino PWM Pin —> MOTOR-PWM Pin
Arduino Analog Pin <— MOTOR-Current Sensor Pin
Popular modules
MC33926
M1_FB     --- Motor1 current sensor output (Arduino)
M1_IN1    --- Motor1 PWM (Arduino)
M1_IN2    --- Motor1 Dir (Arduino)
EN        --- connect with jumper to VDD
M2_FB     --- Motor2 current sensor output (Arduino)
M2_IN1    --- Motor2 PWM (Arduino)
M2_IN2    --- Motor2 Dir (Arduino)
VDD       --- Arduino 5V
L298N
Connect in parallel:
IN1 with IN4
IN2 with IN3
OUT1 with OUT4
OUT2 with OUT3
L6203/STL6201PS
Features: up to 4A
L9958 GND---GND
L9958 VCC---Arduino 5V
L9958 EN---Arduino 5V
L9958 DI---GND
L9958 DIR---Arduino MOTOR_DIR
L9958 PWM---Arduino MOTOR_PWM
L9958 MOTOR(+)---motor(+)
L9958 MOTOR(-)---motor(-)
L9958 POWER(+)---battery(+)
L9958 POWER(-)---battery(-)
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.)
Mower motor (MOSFET)
Choosing a driver
  • price
Short-circuit current
Warning
  • always remove blades
Example measurement:
  • Rotenbach SPM08-320
    • Wheel motor: 8A
    • Mowing motor:
  • Ambrogio L50
    • Wheel motor: 4,5A
    • Mowing motor: 22A
  • Tianchen TC-G158
    • Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
