Ardumower Sunray
- Arduino Due
PCB1.2
- HC-05 module operates at 5v
Code
- Using Arduino IDE, flash the Sunray firmware onto your Arduino Due: https://github.com/Ardumower/Sunray
- Using 'processing_sunray', verify that the bluetooth connection to the Firmware is working.
Bluetooth connection
String serialport = "COM14";
Compass calibration
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and IMU calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be always the same (up to 3 degrees).
Recording / Playback
Mapping
Localization
A particle filter will estimate the robot's position on the map (this is called localization). You can reset the particle filter at any time by clicking 'reset particles'. In perimeter tracking mode, slightly different particle filter parameters will be used than during ordinary mowing. You can set the robot's position manually (this is called kidnapping) by clicking on the map in the user interface. If you move the real robot manually on the ground with your hands in the real world, this is kidnapping too, and the filter has to detect this situation and will reset automatically.
Random mowing
Lane-by-lane mowing
Perimeter tracking
- On the PC, choose 'track'
Particle filter tuning
