Ardumower Sunray
Version vom 16. Juni 2017, 13:46 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Significant changes compared to Azurit Firmware)
  • Optimized for Arduino Due (individual pin interrupt handling, DMA transfers, flexible ADC sampling frequencies...)
  • Optimized for slope and odometry (no longer imprecise time-based driving distances or rotations)
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers) - for PCB1.2 see further below
  • Arduino Due
  • IMU GY-88 (MPU6050, HMC5883L) installed on a 'tower'
  • 2 perimeter coils (left, right), Ardumower perimeter sender
  • Bluetooth module and a PC using an USB Bluetooth dongle (e.g. Delock EDR 150m)
PCB1.2
  1. Remove Jumper JP3 (PowerA3.3) and Jumper JP12 (PowerA5.0) so no Arduino voltage regulators are used. Remove any measurement jumpers as well (Mess3.3 etc.).
  2. Set DC-DC U7 to 3.3v (all old 5v lines and VCC-lines on the PCB will now operate at 3.3v !)
  3. Set DC-DC U6 to 5.0v (all old 3.3v lines on the PCB will now operate at 5.0v ! It's recommended to make big labels on the PCB so you get not confused later!).
  4. MC33926 motor driver and INA169 module and odometry will now operate at 3.3v. Change VCC pin for the following modules to operate them at 5v:
    1. HC-05 module operates at 5v
    2. GY88 module (IMU) operates at 5v (SCL, SDA lines operate at 3.3v).
    3. LM386 modules (perimeter) operate at 5v.
Code
  1. Using Arduino IDE, flash the Sunray firmware onto your Arduino Due: https://github.com/Ardumower/Sunray (you may have to adjust serial ports in config.h).
  2. Install Processing (https://processing.org/download/).
  3. Using Processing, run 'processing_sunray' and verify that the bluetooth connection to the Firmware is working.
Bluetooth connection
 String serialport = "COM14";
Compass calibration
  1. Install IMU module 35cm away from metal parts (suggestion: use a 'tower' for it as you can see in the photos). Use 1m cable so you can move the module out of robot for calibration. Do no use metal parts (screws etc.) within 5cm of the module - use plastic screws. Fixate everything within 5cm of the module. A small movement of a cable etc. will make the calibration useless.Verteileraufputzdose 2017-01-22.jpg
  2. Move IMU out of robot (so you can freely rotate the module without the robot) and power-on robot.
  5. Rotate IMU module slowly into all directions and collect > 20,000 measurements. Calibration ist performed and transmitted continously to robot (robot confirms with a tone).
  1. In 'processing_sunray.pde', setup Bluetooth port.
  2. On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and the IMU calibration status is shown in the user interface (the robot will make short buzzer beeps during gyro calibration time). After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be always the same (up to 3 degrees).
Test functions
  • line : robot should move on a straight line
  • line rev : robot should move reverse on a straight line
  • rotate +90deg : robot should rotate counter-clockwise 90 degree
Recording / Playback
  • outdoor_track.log (robot tracking a 120m perimeter)
  • outdoor_mow_rand.log (robot randomly mowing inside a 120m perimeter with annotated ground truth)
Mapping
Localization
Random mowing
Lane-by-lane mowing
Perimeter tracking
  1. On the PC, choose 'track'
Particle filter tuning
 public static final float steeringNoise = 0.5;
 public static final float distanceNoise = 0.05;
Stuck detection
Discussion / forum thread
