Azurit pfodApp protocol
Example communication:
title [text1] [text2] [text3]
Fore details on all Azurit menus, see the Ardumower code:
https://github.com/Ardumower/ardumower/blob/master/code/ardumower/pfod.cpp
For other pfodApp example code, see here: https://github.com/Ardumower/ardumower/blob/master/code/tests/pfodapp/pfodapp.ino https://github.com/Ardumower/ardumower/blob/master/code/tests/DUE_TESTS_ARDUMOWER/PFOD.ino
