Chassis (English)
Version vom 2. Juli 2017, 11:46 Uhr von Alexanderg (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „This page describes the assembly of the Ardumower chassis that you can purchase via the [https://www.marotronics.de/index.php?k=32 shop] File: shopping.png|l…“)
- Wheels: 250mm diameter
- Gear motors: 2 x DC 24V planetary drive, 33 rpm, with integrated encoders
- Battery: Lithium-Ion 29.4V
- Max. incline: approx. 30%
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
Assembly: required tools
- Screw driver
- Imbus screw driver
