Ardumower Gasoline
Version vom 29. August 2017, 21:51 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Arduino code upload)
Ardumower Gasoline R/C is an ordinary gasoline powered mower converted to remote control (R/C) using Ardumower parts.
Parts list
All parts can be purchased in the shop Shopping.png. Click on a part for more details:
Motors
Free wheel
Control box
Wiring
left BTS7960   Arduino pin
GND            GND
VCC            +5V
R_EN           A1
L_EN           A0
R_PWM          9
L_PWM          10
right BTS7960   Arduino pin
GND             GND
VCC             +5V
R_EN            A3
L_EN            A2
R_PWM           3
L_PWM           11
Wiring Arduino and model R/C receiver
model R/C receiver   Arduino pin
GND                  GND
VCC                  +5V
CH_Steering          5
CH_Speed             6
Arduino code upload
Arduinonano.jpg Finally, download the Arduino IDE and upload this code to your Arduino Nano:
  1. Download and install Arduino IDE
  2. Upload this code to your Arduino Nano:
https://github.com/Ardumower/ardumower/blob/master/code/tests/rcmower/rcmower.ino
