Ardumower Gasoline
Version vom 31. August 2017, 14:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Wiring Arduino and model R/C receiver)
This Do-It-Yourself (DIY) project describes how you can convert your ordinary gasoline mower into a remote controlled (R/C) mower using Ardumower parts.
Video
Video.png Click here for video
Features
  • 2x gear motors running at 31 rpm, 2.45 Nm
  • powered by 29.4v Lithium-Ion battery
  • wireless control via 2.4 Ghz model R/C control
Parts list
Overview
All parts can be purchased in the shop. Click here to add all parts below to your shopping cart: Shopping.png.
Click on a part for more details:
Motors
Free wheel
Control box
Wiring
left BTS7960   Arduino pin
GND            GND
VCC            +5V
R_EN           A1
L_EN           A0
R_PWM          9
L_PWM          10
right BTS7960   Arduino pin
GND             GND
VCC             +5V
R_EN            A3
L_EN            A2
R_PWM           3
L_PWM           11
Connect your model R/C receiver 2 channels (speed, steering) to these Arduino pins:
model R/C receiver   Arduino pin
GND                  GND
VCC                  +5V
CH_Steering          5
CH_Speed             6
Arduino code upload
  1. Download and install Arduino IDE
  2. Upload this code to your Arduino Nano: https://github.com/Ardumower/ardumower/blob/master/code/tests/rcmower/rcmower.ino
Note: After uploading, you can run the Arduino IDE serial console (CTRL+SHIFT+M) at 115200 baud to monitor the R/C signal coming in:
steer=0  speed=100  mleft=255  mright=255
Happy mowing! :-)
Questions, help, discussion
German: http://www.ardumower.de/index.php/de/forum/eure-ardumower-umsetzung/1431-ardumower-gasoline-r-c-benzinrasenmaeher#13672
English: http://www.ardumower.de/index.php/de/forum/your-projects/1432-ardumower-gasoline-r-c-conversion#13674
