Raindancer Firmware (English)
- 1 Download
- 2 Overview
- 5 config.h
- 6 QUICK START TO MOW
- 6.6 Mähmotor Inbetriebnahme
- 6.8 Konfiguration Bluetooth
- 6.10 Erste Testfahrt
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.10 Spiralfahrt
- 7.11 Perimeter Tracking
- 7.12 Schnelle Rückkehr
- 8 Perimeter Sender
- 9 Troubleshooting
Overview
Example: clc.enc
Example: pc.cm,60,30 //drives 60 cm with speed 30 (//drives... does not belong to the command)
Which modes will start when:
Open points
- Dodge objects close to the perimeter (SecondReverse2 in the BHT)
- Program one-sided accessible charging station
Other wishes
- Integrate rain sensor
- SRF08 integration
- GPS map - the mower may not recognize the signal in the middle of the lawn because the signal is too weak. You can then use GPS to see if you are on the lawn area. If you now say that the signal must be detected at least 15m away from the perimeter, you can neglect the signal within the area if the GPS signal indicates that you are on the lawn.
- PCB1.3 with Arduino DUE
- BT module
- 24V power supply
- RTC mit EEPROM
- Durchfahrende Ladestation
clc.v,s Motor stoppen
z //mow motor start
t //mow motor stop
Spiralfahrt
bb.flagCruiseSpiral = true;
Schnelle Rückkehr
Abfrage der States
... } return BH_RUNNING; }
- 1. 12V vorhanden
- 2. 5V vorhanden
