Ardumower PCB
Version vom 14. September 2014, 13:38 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Flashing the Arduino)
Needed parts
v0.9.3
If you know nothing about code, choose v0.9.3 and these parts:
  • Main functions
    • 1 x Arduino Mega 2560
    • 2 x L298N motor driver module
    • 3 x current sensor module ACS712-5
  • Perimeter sender (optional)
    • 1 x Arduino Nano
    • Coil 220µH, Elko 2,2µF/160V, Resistors (1 Ohm, 1K, 4,7K), Diode 1N4448
    • 1 x L298N motor driver module
    • 1 x Arduino Nano
    • 2 x Arduino Sound Sensor Module (must use LM386)
    • Capacitors (2 x 4,7nF, 2 x 100nF), Resistors (2 x 200k), 2 x Receiver coils 85mH
  • Additional modules
SVN version
If you want to be ready for the future, choose SVN and the parts listed there.
Schematics
PCB assembly
...add a high resolution picture of the assembled PCB here...
Download Arduino software
Arduino Version It is verry Importent that you use the Arduino Version 1.5.6-r2 or above AND select the right Board.
You have two options:
First-time calibration
Wheel motors
ADC calibration
Diagnostic
  2. loop()-counts per second
  5. drive home? (1/0)
  11. "com" - compass course
  13. "bat" - Battery voltage
  14. "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
  • config.h (v9.0.3)
  • mower.cpp (SVN version)
pfodApp
