Raindancer Firmware (Deutsch)
- 1 Download
- 2 Überblick
- 5 config.h
- 6 QUICK START TO MOW
- 6.1 Errorhandling
- 6.7 Mähmotor Inbetriebnahme
- 6.9 Konfiguration Bluetooth
- 6.11 Erste Testfahrt
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.11 Spiralfahrt
- 7.12 Perimeter Tracking
- 7.13 Schnelle Rückkehr
- 7.16 Temperatur Sensor
- 7.17 Shutdown Service
- 7.18 GPS Service
- 8 Perimeter Sender
- 9 Ladestation
- 10 Troubleshooting
- Regensensor einbinden
- SRF08 einbinden
- PCB1.3 mit Arduino DUE
- Original Ardumower Mähmotor
- BT Modul
- 24V Spanungsversorgung
- RTC mit EEPROM
- Durchfahrende Ladestation
Errorhandling
error //show errormessage
show.hist //show history
A
clc.v,s Motor stoppen
z //mow motor start
t //mow motor stop
#define CONF_ESCAPEDIR_DEPENDING_ON_BUMPER false // if set to true, the robot rotates in the opposite direction of the activated bumper. If false, the escape direction is random. // only set to true if you use a bumper for left and a bumper for right.
angezeigt.
Spiralfahrt
if(CONF_ACTVATE_AUTO_SPIRAL) { (a) if(bb.mowMotorSensor.motorUnderHeavyLoad) { if(millis()-bb.lastTimeSpiralStarted > 60000ul) { bb.flagCruiseSpiral = true; } } (b) if( (millis()-bb.lastTimeSpiralStarted > 180000ul) && bb.mowMotorSensor.checkIfUnderLoad() ) { // Alle 3 Minuten Spirale starten wenn motor belastet bb.flagCruiseSpiral = true; } }
if ((millis() - lastTransitionTime) > 1000) { // If more than 1sec inside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + 10)); bb.motor.R->setSpeed(-25); }
if ((millis() - lastTransitionTime) > 1800) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECW; bb.motor.L->setSpeed(25); bb.motor.R->setSpeed(-25);
if ((millis() - lastTransitionTime) > 1000) { // If more than 2sec Outside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +5)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); } if ((millis() - lastTransitionTime) > 2000) { // If more than 3.5sec Outside rotate full bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); }
if (bb.perimeterSensoren.isLeftOutside() == true) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); waitForRightInside = true; }
Schnelle Rückkehr
virtual NodeStatus onUpdate(Blackboard& bb) { ...
//============================================ // Calculate driven angle every 500ms. //============================================ if (millis() - lastRunAngleCalculation >= 500) { lastRunAngleCalculation = millis(); ... angle = (cmL - cmR) * 57.2957795f / CONF_DISTANCE_BETWEEN_WHEELS_CM; if (flagShowFindTriangleStates) { errorHandler.setInfoNoLog(F("Winkel: %f cmL %f cmR %f\r\n"), angle, cmL, cmR); } }
Abfrage der States
// Check for left curve / right curve / second left curve switch (state) {
case 0: // search for left curve if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s0 set state = 1 Left turn found angle: %f ms: %lu\r\n"), angle, millis()); } bb.motor.startDistanceMeasurementTriangle(); ... state = 1; // Activate triangle searching } break;
case 1: // search for right turn distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 55) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 0 distance %f > 55 ms: %lu\r\n"), distance, millis()); } } else if (angle > 50) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 2 angle %f distance %f < 50\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 2; } break;
case 2: // search for second left curve distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 50) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 0 distance %f > 50 ms: %lu\r\n"), distance, millis()); } } else if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 3 angle %f distance %f < -25\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 3; } break;
case 3: if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s3 set state=0 Cross Lawn Activated\r\n")); } state = 0; return BH_SUCCESS; break;
... } return BH_RUNNING; }
Siehe Bild:
Temperatur Sensor
#define DHTTYPE DHT22
temp.show
Shutdown Service
Mit dem Befehl:
poweroff
GPS Service
set.cco,1
set.cco,0
Mit
gps.show
const float CONF_LAT_POLYGON_Y[] = { 54.083245f, 54.084068f, 54.084679f, 54.085623f, 54.084018f }; // Latitude polygon points const float CONF_LON_POLYGON_X[] = { 10.447986f, 10.447055f, 10.446015f, 10.447120f, 10.44930f }; // Longitudinal polygon points const int CONF_NUMBER_OF_POLYGON_POINTS = 5; // The number of the ploygon points
Der Punkt kann dann aus der Zeile !03,$GPRMC lat: 53.08744800,N lon: 9.44867700,E entnommen werden. Hier für Latitude = 54.087448 und Longitude=10.448677.
eingeschaltet.
- 1. 12V vorhanden
- 2. 5V vorhanden
Ladestation
Kopfladestation
gohome
tpt
Zum verlassen der Ladestation
area,0
Durchgangsladestation
gohome
tpt
area,10
