Ardumower Sunray
- 3 Requirements
- 4 Bluetooth BLE module
- 5 PCB1.3 GPS
- 6 RTK base
- 7 RTK rover
- 8 Rover configuration
- 9 Firmware
- 10 Phone App
- 11 How does it work
- 12 Discussion / forum thread
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE module (CC2540) and a smartphone (Android/iOS)
Install Bluetooth 4.0/BLE module as shown below.
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB back side)!
PCB1.3 GPS
- Make sure you have the simpleRTK2B marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect Xbee LongRange antenna
- Connect GPS multifrequency antenna
- Connect USB 5v to power base module
- Make sure you have the simpleRTK2B marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect XBee LongRange antenna
- Connect PCB1.3_GPS_GND to simpleRTK2B GND
- Connect PCB1.3_GPS_5V to simpleRTK2B 5V_IN
- Connect PCB1.3_GPS_TX to simpleRTK2B TX1
- Connect PCB1.3_GPS_RX to simpleRTK2B RX1
- Connect simpleRTK2B IOREF to simpleRTK2B 5V_OUT (to choose signal voltage level 5v)
Rover configuration
1. Connect rover module via USB to your PC.
3. Choose 'Receiver->Connection' and choose your rover.
4. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, etc.). For each message, make sure the selected message is NOT activated for UART1. Example for message '01-22 NAV-CLOCK':
5. Finally only activate message '01-3C NAV-RELPOSNED' for UART1.
7. Choose configuration message 'CFG (Configuration)' and click on 'Send' to make the configuration in the rover persistent.
Firmware
3. Start Arduino IDE, and upload the sketch to your PCB1.3.
1.1. Download Viewer App:
How does it work
- coming soon
- coming soon
