Ardumower Sunray
600px
Demo video: coming soon
  • Optimized for Arduino Due
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers)
  • Arduino Due
  • SimpleRTK2B - starter kit LR IP67
  • Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
Bluetooth BLE module
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB1.3 back side)!
4. Set JP12 (GPS voltage) to 5V
5. Set JP7 (GPS signal level) to 5V
  2. Connect Xbee LongRange antenna
  5. Install the GPS base antenna - it should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof.
PCB 600px
  2. Connect XBee LongRange antenna
  3. Connect GPS multifrequency antenna
Rover configuration
1. Connect SimpleRTK ROVER module USB port marked as 'POWER+GPS' to your PC. Do NOT turn on the Ardumower!
4. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is NOT activated for UART1. Do NOT change anything for the ports UART2, USB etc. - only deselect all messages for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
5. Finally only activate message '01-3C NAV-RELPOSNED' for UART1.
Firmware (Arduino Code)
Discussion / forum thread
  1. coming soon
