Ardumower Sunray
- 3 Requirements
- 4 Bluetooth BLE UART module
- 5 PCB1.3 GPS pin fix
- 6 RTK base
- 7 RTK rover
- 8 Rover configuration
- 9 Firmware (Arduino Code)
- 10 Phone App
- 11 Troubleshooting
- 12 Discussion / forum thread
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB1.3 back side)!
4. Set JP12 (GPS voltage) to 5V
5. Set JP7 (GPS signal level) to 5V
- Make sure you have the simpleRTK2B module marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect Xbee LongRange antenna
- Connect GPS multifrequency patch antenna
- Connect a USB 5v power supply to the USB port marked as 'POWER+GPS'
- Install the GPS base antenna - it should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof.
- Make sure you have the simpleRTK2B module marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect XBee LongRange antenna
- Connect GPS multifrequency antenna
- Connect PCB1.3_GPS_GND to simpleRTK2B GND
- Connect PCB1.3_GPS_5V to simpleRTK2B 5V_IN
- Connect PCB1.3_GPS_TX to simpleRTK2B TX1
- Connect PCB1.3_GPS_RX to simpleRTK2B RX1
- Connect simpleRTK2B IOREF to simpleRTK2B 5V_OUT (to choose signal voltage level 5v)
- Install XBee antenna and GPS antenna on the Ardumower
Rover configuration
1. Connect SimpleRTK ROVER module USB port marked as 'POWER+GPS' to your PC. Do NOT turn on the Ardumower!
4. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is NOT activated for UART1. Do NOT change anything for the ports UART2, USB etc. - only deselect all messages for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
5. Finally only activate message '01-3C NAV-RELPOSNED' for UART1.
- coming soon
