Ardumower Sunray
- 3 Requirements
- 4 Bluetooth BLE UART module
- 5 PCB1.3 GPS pin fix
- 6 RTK base
- 7 RTK rover
- 8 Rover configuration
- 9 Firmware (Arduino Code)
- 10 Phone App
- 11 Troubleshooting
- 12 Discussion / forum thread
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
- Make sure you have the simpleRTK2B module marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect Xbee LongRange antenna
- Connect GPS multifrequency patch antenna
- Connect a USB 5v power supply to the USB port marked as 'POWER+GPS'
- Install the GPS base antenna - it should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof.
- Make sure you have the simpleRTK2B module marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect XBee LongRange antenna
- Connect GPS multifrequency antenna
- Connect PCB1.3_GPS_GND to simpleRTK2B GND
- Connect PCB1.3_GPS_5V to simpleRTK2B 5V_IN
- Connect PCB1.3_GPS_TX to simpleRTK2B TX1
- Connect PCB1.3_GPS_RX to simpleRTK2B RX1
- Connect simpleRTK2B IOREF to simpleRTK2B 5V_OUT (to choose signal voltage level 5v)
- Install XBee antenna and GPS antenna on the Ardumower
Rover configuration
1. Connect SimpleRTK ROVER module USB port marked as 'POWER+GPS' to your PC. Do NOT turn on the Ardumower!
4. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is NOT activated for UART1. Do NOT change anything for the ports UART2, USB etc. - only deselect all messages for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
Repeat this step for all messages in the listbox and deselect each message for UART1.
5. Finally only activate message '01-3C NAV-RELPOSNED' for UART1.
- coming soon
