Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimpleRTK kit and a phone (Android/iOS).
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- | Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
- Make sure you have the simpleRTK2B module marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect Xbee LongRange dipole antenna
- Connect GPS multifrequency patch antenna
- Connect a USB 5v power supply to the USB port marked as 'POWER+GPS'
- Install the GPS base antenna - it should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof. Alternatively, if you have an open area (without trees and other obstacles), you can install the base antenna on a tripod.
- Make sure you have the simpleRTK2B module marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
- Connect XBee LongRange dipole antenna
- Connect PCB1.3_GPS_GND to simpleRTK2B GND
- Connect PCB1.3_GPS_5V to simpleRTK2B 5V_IN
- Connect PCB1.3_GPS_TX to simpleRTK2B TX1
- Connect PCB1.3_GPS_RX to simpleRTK2B RX1
- Connect simpleRTK2B IOREF to simpleRTK2B 5V_OUT (to choose signal voltage level 5v)
- Install XBee antenna and GPS antenna on the Ardumower
1. Connect SimpleRTK ROVER module USB port marked as 'POWER+GPS' to your PC. Do NOT turn on the Ardumower!
4. In this step we want to turn off all broadcast messages except one. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is turned off for UART1. Do NOT change anything for the ports UART2, USB etc. - only turn off all messages for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
5. Finally, activate message '01-3C NAV-RELPOSNED' for UART1 (this is the only message we want to be broadcast).
6. Choose configuration message 'PRT (Ports)', choose 'UART1', and set baudrate to 115200 for UART1:
Firmware (Arduino Code)
Discussion / forum thread
- coming soon
